当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
Note how the blade is oriented on the lawn mower for reassembly.
Do not grab it from the sharp parts of the blade.
Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
