跳转到主内容
How to Sharpen Troy-Bilt TB110 Lawnmower Blades
你所需要的
  1. How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 1 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 1 中的图像 2,2
    • Disconnect the spark plug wire.
    • This step is critical to avoid an accidental startup since we are working on the blade.
  2. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 2 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 2 中的图像 2,2
    • Put saran wrap on the inside of the gas cap.
    • This is done to prevent gas from spilling out when we turn over the lawnmower.
  3. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 3 中的图像 1,1
    • Turn the lawn mower over on its side.
  4. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 4 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 4 中的图像 2,2
    • Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
    • Note how the blade is oriented on the lawn mower for reassembly.
    • Do not grab it from the sharp parts of the blade.
  5. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 5 中的图像 1,1
    • Clean the blade with a scraper or a wire brush to remove grass residue .
  6. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 6 中的图像 1,1
    • Secure the blade in a vise.
  7. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 7 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 7 中的图像 2,2
    • Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
    • Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
    • The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
  8. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 8 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 8 中的图像 2,2
    • Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
    • Again be careful not to hold the blade by the sharp edges.
  9. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 9 中的图像 1,2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: 步骤 9 中的图像 2,2
    • Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
    • Plug the spark plug wire in until you hear a click.
终点
另外一个人完成了本指南。
Andrew DePari
于03/24/21注册
193 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 46
总计 1,271
