跳转到主内容
How to Sew a Hole and reattach zippers to a purse
你所需要的
  1. How to Sew a Hole and reattach zippers to a purse, Hole and Zippers: 步骤 1 中的图像 1,1
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. How to Sew a Hole and reattach zippers to a purse: 步骤 2 中的图像 1,1
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
  3. How to Sew a Hole and reattach zippers to a purse: 步骤 3 中的图像 1,2 How to Sew a Hole and reattach zippers to a purse: 步骤 3 中的图像 2,2
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
  4. How to Sew a Hole and reattach zippers to a purse: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to grab one side of the opened coil.
  5. How to Sew a Hole and reattach zippers to a purse: 步骤 5 中的图像 1,1
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
  6. How to Sew a Hole and reattach zippers to a purse: 步骤 6 中的图像 1,1
    • Place one side of the coil inside the zipper slider just a little using tweezers.
  7. How to Sew a Hole and reattach zippers to a purse: 步骤 7 中的图像 1,2 How to Sew a Hole and reattach zippers to a purse: 步骤 7 中的图像 2,2
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
  8. How to Sew a Hole and reattach zippers to a purse: 步骤 8 中的图像 1,2 How to Sew a Hole and reattach zippers to a purse: 步骤 8 中的图像 2,2
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
  9. How to Sew a Hole and reattach zippers to a purse: 步骤 9 中的图像 1,3 How to Sew a Hole and reattach zippers to a purse: 步骤 9 中的图像 2,3 How to Sew a Hole and reattach zippers to a purse: 步骤 9 中的图像 3,3
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
结论
2等其他人完成本指南。
ReNieka Perry
于01/21/18注册
223 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 100
总计 1,948
