跳转到主内容
How to Sew a Cloth Seat Cushion Strap
你所需要的
  1. How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: 步骤 1 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: 步骤 1 中的图像 2,2
    • Find the hole in the seat cushion.
  2. How to Sew a Cloth Seat Cushion Strap: 步骤 2 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 2 中的图像 2,2
    • Cut a piece of thread long enough to fit the hole.
    • Put the thread through the eye of the needle.
  3. How to Sew a Cloth Seat Cushion Strap: 步骤 3 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 3 中的图像 2,2
    • Tie a knot at the end of the thread.
  4. How to Sew a Cloth Seat Cushion Strap: 步骤 4 中的图像 1,1
    • Sandwich the strap in between the two pieces of fabric.
  5. How to Sew a Cloth Seat Cushion Strap: 步骤 5 中的图像 1,1
    • Push the needle from the inside of the cushion, around where the broken seam is.
  6. How to Sew a Cloth Seat Cushion Strap: 步骤 6 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 6 中的图像 2,2
    • Use a small stitch over the material.
    • Pull the needle until thread is taut.
  7. How to Sew a Cloth Seat Cushion Strap: 步骤 7 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 7 中的图像 2,2
    • Use a small stitch under the material.
    • Pull the needle until the thread is taut.
  8. How to Sew a Cloth Seat Cushion Strap: 步骤 8 中的图像 1,1
    • Continue the same alternating stitch pattern of over and under until the end of the hole.
  9. How to Sew a Cloth Seat Cushion Strap: 步骤 9 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 9 中的图像 2,2
    • Push the needle in through the end of the sewn hole.
  10. How to Sew a Cloth Seat Cushion Strap: 步骤 10 中的图像 1,3 How to Sew a Cloth Seat Cushion Strap: 步骤 10 中的图像 2,3 How to Sew a Cloth Seat Cushion Strap: 步骤 10 中的图像 3,3
    • Wrap the thread around the needle two times.
    • Tie off your thread with a knot.
  11. How to Sew a Cloth Seat Cushion Strap: 步骤 11 中的图像 1,1
    • Pull the knot tightly.
  12. How to Sew a Cloth Seat Cushion Strap: 步骤 12 中的图像 1,3 How to Sew a Cloth Seat Cushion Strap: 步骤 12 中的图像 2,3 How to Sew a Cloth Seat Cushion Strap: 步骤 12 中的图像 3,3
    • Push the needle through the side of the cushion.
  13. How to Sew a Cloth Seat Cushion Strap: 步骤 13 中的图像 1,2 How to Sew a Cloth Seat Cushion Strap: 步骤 13 中的图像 2,2
    • Pull until taut and cut off the excess thread.
    • This will hide the excess thread.
  14. How to Sew a Cloth Seat Cushion Strap: 步骤 14 中的图像 1,1
    • Now, your seat cushion is fixed!
终点
2等其他人完成本指南。
Deepa Bhat
于04/25/24注册
253 声望
撰写一个指南
团队
UC Davis, Team 3-5, Whithaus Spring 2024 UC Davis, Team 3-5, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S3G5
3 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 35
总计 486
