跳转到主内容
How to Secure a Hook and Eye Fastener Properly
你所需要的
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: 步骤 1 中的图像 1,1
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: 步骤 2 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 2 中的图像 2,2
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: 步骤 3 中的图像 1,1
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: 步骤 4 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 4 中的图像 2,2
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: 步骤 5 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 5 中的图像 2,2
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: 步骤 6 中的图像 1,1
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: 步骤 7 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 7 中的图像 2,2
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: 步骤 8 中的图像 1,1
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: 步骤 9 中的图像 1,1
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: 步骤 10 中的图像 1,1
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: 步骤 11 中的图像 1,1
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: 步骤 12 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 12 中的图像 2,2
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: 步骤 13 中的图像 1,1
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: 步骤 14 中的图像 1,2 How to Secure a Hook and Eye Fastener Properly: 步骤 14 中的图像 2,2
    • Then repeat step 8 and 9.
    • It should look like this at the end.
终点
Cecilia
于05/10/21注册
229 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 73
总计 2,301
