跳转到主内容
How to Safely Remove Stickers from a Hydro Flask
你所需要的
  1. How to Safely Remove Stickers from a Hydro Flask, How to Safely Remove Stickers from a Hydro Flask: 步骤 1 中的图像 1,1
    • Soak the water bottle in warm water for 10 minutes.
  2. How to Safely Remove Stickers from a Hydro Flask: 步骤 2 中的图像 1,2 How to Safely Remove Stickers from a Hydro Flask: 步骤 2 中的图像 2,2
    • Dry the water bottle with a towel.
  3. How to Safely Remove Stickers from a Hydro Flask: 步骤 3 中的图像 1,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 3 中的图像 2,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 3 中的图像 3,3
    • Turn the hair dryer on high heat.
    • Apply heat to each sticker for 30 seconds.
    • Slowly peel the sticker off while applying heat.
    • Caution: Be careful not to burn your fingers when peeling off the sticker.
  4. How to Safely Remove Stickers from a Hydro Flask: 步骤 4 中的图像 1,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 4 中的图像 2,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 4 中的图像 3,3
    • Lather the water bottle in warm soapy water.
    • Scrub away at the residue with a sponge.
    • Dry down the water bottle with a towel.
  5. How to Safely Remove Stickers from a Hydro Flask: 步骤 5 中的图像 1,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 5 中的图像 2,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 5 中的图像 3,3
    • Pour the isopropyl alcohol onto a cotton pad so that it is fully soaked.
    • Using pressure, rub the residue off of the water bottle with the cotton pad.
  6. How to Safely Remove Stickers from a Hydro Flask: 步骤 6 中的图像 1,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 6 中的图像 2,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 6 中的图像 3,3
    • Scrape off the residue with a card. Scrape up to down.
    • Scrape from right to left.
  7. How to Safely Remove Stickers from a Hydro Flask: 步骤 7 中的图像 1,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 7 中的图像 2,3 How to Safely Remove Stickers from a Hydro Flask: 步骤 7 中的图像 3,3
    • Coat a cotton swab in the isopropyl alcohol.
    • With pressure, rub off the residue with the cotton swab.
    • For any difficult residue follow this step.
  8. How to Safely Remove Stickers from a Hydro Flask: 步骤 8 中的图像 1,2 How to Safely Remove Stickers from a Hydro Flask: 步骤 8 中的图像 2,2
    • Enjoy your new water bottle!
终点
Karley Makar
于11/05/24注册
157 声望
撰写一个指南
团队
UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S4G5
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 35
总计 308
