跳转到主内容
How to Safely Discharge a Capacitor
你所需要的
  1. How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: 步骤 1 中的图像 1,3 How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: 步骤 1 中的图像 2,3 How to Safely Discharge a Capacitor, How to Safely Discharge a Capacitor: 步骤 1 中的图像 3,3
    • Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous.
    • Aluminum and Tantalum Electrolytic capacitors can pack a lot into a relatively small volume. They’re well suited to high-voltage applications because of their relatively high maximum voltage ratings.
    • Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
  2. How to Safely Discharge a Capacitor: 步骤 2 中的图像 1,2 How to Safely Discharge a Capacitor: 步骤 2 中的图像 2,2
    • Identify all the capacitors in your device.
    • Locate where the capacitor's cathode will be by finding the side of the capacitor marked with a "-" (minus) symbol. This side will correspond to the negative lead, or cathode.
  3. How to Safely Discharge a Capacitor: 步骤 3 中的图像 1,2 How to Safely Discharge a Capacitor: 步骤 3 中的图像 2,2
    • Flip the circuit board over to access the capacitor's leads.
    • Avoid touching any metal when handling your electronics. Before being safely discharged, circuit boards may contain excess energy that can be dangerous.
  4. How to Safely Discharge a Capacitor: 步骤 4 中的图像 1,2 How to Safely Discharge a Capacitor: 步骤 4 中的图像 2,2
    • Touch the black, or negative, tip of the discharge pen to the capacitor's cathode.
    • This is the lead that you previously identified with the minus symbol on the side of the capacitor.
    • Touch the red, or positive, tip of the discharge pen to the other lead, the capacitor's anode.
    • Do NOT connect the positive and negative terminals of the capacitor together with standard wire, screwdrivers or wrenches as this will damage the capacitor and could cause bodily harm to the user.
  5. How to Safely Discharge a Capacitor: 步骤 5 中的图像 1,2 How to Safely Discharge a Capacitor: 步骤 5 中的图像 2,2
    • Watch the LED indicator on your discharge tool. If there is still a charge in the capacitor, the LED should glow red until the capacitor is fully discharged.
    • Once the light is no longer on, your capacitor is fully discharged and safe to handle.
结论
Your capacitor is now safe to be handled, shock free!
50等其他人完成本指南。
Corey Brown
于06/24/16注册
9,274 声望
创作了11篇指南
1指南评论
Thanks a lot for the cool tips
prince - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 221
过去 30 天: 639
总计 58,528
