跳转到主内容
How to Run MirageOS on TI-NSpire
你所需要的
  1. How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: 步骤 1 中的图像 1,2 How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: 步骤 1 中的图像 2,2
    • Download the latest version of MirageOS and the latest version of MOSPATCH onto your computer.
    • And if you do not already have it, the TI-NSpire connectivity software.
    • Save the files in a place you can access easily, preferably the desktop.
  2. How to Run MirageOS on TI-NSpire: 步骤 2 中的图像 1,1
    • Connect your TI-NSpire to your computer using the TI Calculator Link Cable.
  3. How to Run MirageOS on TI-NSpire: 步骤 3 中的图像 1,2 How to Run MirageOS on TI-NSpire: 步骤 3 中的图像 2,2
    • Open TI Connect and double click "TI DeviceExplorer."
    • A new window named Device Explorer will open.
  4. How to Run MirageOS on TI-NSpire: 步骤 4 中的图像 1,2 How to Run MirageOS on TI-NSpire: 步骤 4 中的图像 2,2
    • Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window.
  5. How to Run MirageOS on TI-NSpire: 步骤 5 中的图像 1,3 How to Run MirageOS on TI-NSpire: 步骤 5 中的图像 2,3 How to Run MirageOS on TI-NSpire: 步骤 5 中的图像 3,3
    • Now on your calculator, bring up the catalog by pressing 2nd + 0 (catalog).
    • Press the down arrow key to scroll down to the "Asm(" function (the last item) and press "ENTER".
    • Press PRGM, select MOSPATCH using the arrow keys, and press "ENTER".
  6. How to Run MirageOS on TI-NSpire: 步骤 6 中的图像 1,2 How to Run MirageOS on TI-NSpire: 步骤 6 中的图像 2,2
    • The calculator should now display "Asm(prgmMOSPATCH".
    • Press "ENTER". The calculator will display "DONE" indicating that you can now run MirageOS on your TI-NSpire!
结论
Now that you have MirageOS running on your TI-NSpire, download some games and try them out! http://www.ticalc.org/pub/83plus/asm/gam...
John Baek
于09/27/12注册
31 声望
创作了4篇指南
团队
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G52
5 名成员
创作了12篇指南
2条评论
show an example of running a game. and is the 84 keypad required?
trogfield - 回复
it did not work for me can you help me fix that problem because ive been progaming my own and it did not work so can you find another way because im a big fan of your work it helps me alot
David Fife - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,441
