跳转到主内容
加入维修社区 - 创建账户
How to Run First Aid with Disk Utility
    1. How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 步骤 1 中的图像 1,2 How to Run First Aid with Disk Utility, How to Run First Aid with Disk Utility: 步骤 1 中的图像 2,2
      • Open Disk Utilities, which can be found in the Applications folder under Utilities
      • Pro Tip: Take the shortcut and use Spotlight. (This method is used in this guide)
      添加评论
    2. How to Run First Aid with Disk Utility: 步骤 2 中的图像 1,2 How to Run First Aid with Disk Utility: 步骤 2 中的图像 2,2
      • Once the Disk Utility App opens, click the "View" menu.
      • Select "Show All Devices"
      • Older versions of macOS may not have this button. If so, skip to the next step.
      询问修复机器人
      添加评论
    3. How to Run First Aid with Disk Utility: 步骤 3 中的图像 1,1
      • In the Sidebar, click the last volume in the list.
      • By default it will likely be named "Macintosh HD - Data" or simply "Macintosh HD" on Macs running 10.14 Mojave or earlier.
      询问修复机器人
      添加评论
    4. How to Run First Aid with Disk Utility: 步骤 4 中的图像 1,3 How to Run First Aid with Disk Utility: 步骤 4 中的图像 2,3 How to Run First Aid with Disk Utility: 步骤 4 中的图像 3,3
      • Click on the First Aid button at the top of the window.
      • A dialogue box will appear asking if you would like to run First Aid.
      • Click "Run".
      • A second dialogue box will pop up prompting for acknowledgement that verifying your startup disk will cause it to be non-responsive.
      • Click “Continue”.
      询问修复机器人
      添加评论
    5. How to Run First Aid with Disk Utility: 步骤 5 中的图像 1,3 How to Run First Aid with Disk Utility: 步骤 5 中的图像 2,3 How to Run First Aid with Disk Utility: 步骤 5 中的图像 3,3
      • This procedure will take a few minutes to complete. The machine may freeze up, or lock up during this procedure.
      • Patience is key here.
      • Disk repair may fail, or give an error message. Restart your machine and run it again if this is the case, it may repair further issues.
      • Once completed, click done.
      • Pro Tip: To see the entire process including corrected errors, click on the arrow next to 'Show Details'.
      • Repeat this on all items in the Disk Utility list for your internal drive. Move upward through the list. Order of operations is all volumes first, then the container and finally the disk itself.
      添加评论
    6. How to Run First Aid with Disk Utility: 步骤 6 中的图像 1,1
      • If you continue to receive errors, repeat this process using the Disk Utility function in Internet Recovery.
      询问修复机器人
      添加评论
结论
Close Disk Utility, and the internal drive should be ready to go.
取消:我没有完成这个指南。
44等其他人完成本指南。
Mike
于11/01/10注册
14,505 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 51
过去 30 天: 270
总计 23,200
