当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
To begin fixing the lever spring, remove the top metal plate of the toaster.
To do this, locate the four metal bending couples that keep it attached (two in front, two in back).
Bend down each of the bending couples that are currently at a ninety degree angle.
Lift the plate and remove.
这个步骤还没有翻译 帮忙翻译一下
Locate the metal "U" bracket that is in the middle of the two toaster slots.
The bracket is secured by two protruding metal strips that are twisted and one metal strip on the lever side that is bent over the pole.
Using pliers or tweezers, untwist the two metal strips.
Use pliers or tweezers to unfold the metal sheet that keeps the pole in place.
Pull up on the bracket and remove.
