跳转到主内容
How to Rewire a Lamp
你所需要的
  1. How to Rewire a Lamp, Cord: 步骤 1 中的图像 1,3 How to Rewire a Lamp, Cord: 步骤 1 中的图像 2,3 How to Rewire a Lamp, Cord: 步骤 1 中的图像 3,3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: 步骤 2 中的图像 1,3 How to Rewire a Lamp: 步骤 2 中的图像 2,3 How to Rewire a Lamp: 步骤 2 中的图像 3,3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: 步骤 3 中的图像 1,3 How to Rewire a Lamp: 步骤 3 中的图像 2,3 How to Rewire a Lamp: 步骤 3 中的图像 3,3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: 步骤 4 中的图像 1,2 How to Rewire a Lamp: 步骤 4 中的图像 2,2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: 步骤 5 中的图像 1,3 How to Rewire a Lamp: 步骤 5 中的图像 2,3 How to Rewire a Lamp: 步骤 5 中的图像 3,3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: 步骤 6 中的图像 1,3 How to Rewire a Lamp: 步骤 6 中的图像 2,3 How to Rewire a Lamp: 步骤 6 中的图像 3,3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
终点
3等其他人完成本指南。
Molly
于10/20/17注册
125 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 104
总计 2,955
