跳转到主内容
How to Reupholster a Bench Cushion
你所需要的
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 步骤 1 中的图像 1,3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 步骤 1 中的图像 2,3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: 步骤 1 中的图像 3,3
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: 步骤 2 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 2 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 2 中的图像 3,3
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: 步骤 3 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 3 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 3 中的图像 3,3
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: 步骤 4 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 4 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 4 中的图像 3,3
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: 步骤 5 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 5 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 5 中的图像 3,3
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: 步骤 6 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 6 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 6 中的图像 3,3
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: 步骤 7 中的图像 1,3 How to Reupholster a Bench Cushion: 步骤 7 中的图像 2,3 How to Reupholster a Bench Cushion: 步骤 7 中的图像 3,3
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
终点
2等其他人完成本指南。
Xochitl Vara
于01/26/22注册
169 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-4, Briggs Spring 2022 CSU Los Angeles, Team 4-4, Briggs Spring 2022 的会员
CSULA-BRIGGS-S22S4G4
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 24
总计 721
