跳转到主内容
How to Resurface a Fishing Lure
你所需要的
  1. How to Resurface a Fishing Lure, How to Resurface a Fishing Lure: 步骤 1 中的图像 1,1
    • Evaluate the material your lures are made from. This will affect your process slightly.
  2. How to Resurface a Fishing Lure: 步骤 2 中的图像 1,2 How to Resurface a Fishing Lure: 步骤 2 中的图像 2,2
    • Remove the treble hooks and keyrings from the lure body.
    • The hooks are very sharp!
  3. How to Resurface a Fishing Lure: 步骤 3 中的图像 1,2 How to Resurface a Fishing Lure: 步骤 3 中的图像 2,2
    • Sand your lures. They can either be fully sanded or just scuffed on the surface. This helps the polyurethane bond to the surface.
    • Lures can be repainted with acrylic paints but that is out of the scope of this tutorial.
  4. How to Resurface a Fishing Lure: 步骤 4 中的图像 1,2 How to Resurface a Fishing Lure: 步骤 4 中的图像 2,2
    • Wipe the freshly sanded lures with a wet cloth. Allow it to fully dry.
  5. How to Resurface a Fishing Lure: 步骤 5 中的图像 1,2 How to Resurface a Fishing Lure: 步骤 5 中的图像 2,2
    • Tie a string to the lures and dip the lures fully into the polyurethane.
    • Do this step in a large and well ventilated space. Fumes from your polyurethane should not be inhaled.
  6. How to Resurface a Fishing Lure: 步骤 6 中的图像 1,1
    • Hang your lures up to dry for at least 24 hours.
结论
All that is necessary after the lure's new surface has cured is to reattach the keyring and treble hooks.
另外一个人完成了本指南。
Zach Solka
于03/30/16注册
149 声望
撰写一个指南
团队
Michigan Tech, Team 1-24, Lauer Spring 2016 Michigan Tech, Team 1-24, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G24
1 名成员
创作了2篇指南
2条评论
Looking for your first rod so you can take part in the great sport of fishing? Have you looked through some catalogs or browsed in sporting goods store and are already confused? All these new words to learn. Spinning fishing rods? Bait-casting '''fishing rods'''? Spin casting fishing rods? What do all these things mean?
mahbub_rahman - 回复
Very interesting post. Every step explains with the images are really helpful for the beginners. I love fishing in Puerto Vallarta and your post helps me a lot to resurface my fishing lure. Thanks a million and please keep up the effective work.
Marlas PV Landing - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 801
