跳转到主内容
How to Restring a Hoodie
你所需要的
  1. How to Restring a Hoodie, How to Restring a Hoodie: 步骤 1 中的图像 1,2 How to Restring a Hoodie, How to Restring a Hoodie: 步骤 1 中的图像 2,2
    • Remove the string from the hoodie.
  2. How to Restring a Hoodie: 步骤 2 中的图像 1,3 How to Restring a Hoodie: 步骤 2 中的图像 2,3 How to Restring a Hoodie: 步骤 2 中的图像 3,3
    • Pin the safety pin to one end of the string.
    • Safety pin can cause injury if handled incorrectly.
  3. How to Restring a Hoodie: 步骤 3 中的图像 1,2 How to Restring a Hoodie: 步骤 3 中的图像 2,2
    • Insert the end of the string with the safety pin into one of the holes of the hoodie.
  4. How to Restring a Hoodie: 步骤 4 中的图像 1,1
    • Pinch the fabric to help the safety pin move through the hoodie.
  5. How to Restring a Hoodie: 步骤 5 中的图像 1,1
    • Straighten out the fabric while holding the safety pin.
  6. How to Restring a Hoodie: 步骤 6 中的图像 1,3 How to Restring a Hoodie: 步骤 6 中的图像 2,3 How to Restring a Hoodie: 步骤 6 中的图像 3,3
    • Continue pinching and straightening the fabric while holding onto the safety pin to move the string through the hoodie.
    • Do this until the safety pin reaches the hole on the other side of the hoodie.
  7. How to Restring a Hoodie: 步骤 7 中的图像 1,1
    • Pull the string end with the safety pin completely out of the hole.
  8. How to Restring a Hoodie: 步骤 8 中的图像 1,1
    • Remove the safety pin from the string.
结论
After restringing the hoodie, you can wear it without fear of uneven or missing strings.
Victoria Longa
于03/29/21注册
157 声望
撰写一个指南
团队
Marist, Team S1-G3, Chaterdon Spring 2021 Marist, Team S1-G3, Chaterdon Spring 2021 的会员
MARS-CHATERDON-S21S1G3
2 名成员
创作了1篇指南
一条评论
Great tutorial but I have two comments/suggestions:
First, when inserting the pin into the hoodie I think it’d be even easier to pass the pin through the hoodie if the pin was inserted HEAD FIRST - meaning that the thicker, curved head should enter first. I run electrical wiring using a snake with a looped end. We often have to wrap electrical tape around the part of the looped end of the snake so that any open edges don’t catch on anything as the snake is being pulled. Similar concept applies here. Putting the pin in head first would probably facilitate it passing through more easily.
Second suggestion is to cut up a wire hanger and create a make shift snake/pull. Run it through the channel of the hoodie out the other end. Once through, loop one end of wire, put in string and tie a knot larger than the loop, tape any rough edges with electrical tape, and slowly pull through. Crochet needles or some other such knitting/crocheting tools might work well too.
Mark DiRollo - 回复
添加评论
浏览统计数据:
过去 24 小时: 36
过去 7 天: 241
过去 30 天: 1,108
总计 6,151
