跳转到主内容
How to Restring a French Horn
你所需要的
  1. How to Restring a French Horn, How to Restring a French Horn: 步骤 1 中的图像 1,3 How to Restring a French Horn, How to Restring a French Horn: 步骤 1 中的图像 2,3 How to Restring a French Horn, How to Restring a French Horn: 步骤 1 中的图像 3,3
    • Place your horn where the back is easily accessible.
    • Loosen the set of screws, but DON’T take them out! Just loosen them enough that the string can wrap around.
  2. How to Restring a French Horn: 步骤 2 中的图像 1,3 How to Restring a French Horn: 步骤 2 中的图像 2,3 How to Restring a French Horn: 步骤 2 中的图像 3,3
    • Cut about 7-8 inches of string only if you are going to use a brand new roll of string, and tie a small knot on one end of the string.
    • If it is the exact string, make sure there is a knot at the one end of the string.
    • With the knot, the string should be about 51/2-6 inches.
  3. How to Restring a French Horn: 步骤 3 中的图像 1,2 How to Restring a French Horn: 步骤 3 中的图像 2,2
    • Put the string in the top hole of the valve and pull.
    • You are going to pull it toward the bottom and wrap it at the bottom of the rotor post.
  4. How to Restring a French Horn: 步骤 4 中的图像 1,3 How to Restring a French Horn: 步骤 4 中的图像 2,3 How to Restring a French Horn: 步骤 4 中的图像 3,3
    • Wrap the string around the screw and tighten the screw.
  5. How to Restring a French Horn: 步骤 5 中的图像 1,3 How to Restring a French Horn: 步骤 5 中的图像 2,3 How to Restring a French Horn: 步骤 5 中的图像 3,3
    • Pull the string to wrap the top of the rotor.
    • Put the string into the hole at the bottom of the valve.
  6. How to Restring a French Horn: 步骤 6 中的图像 1,3 How to Restring a French Horn: 步骤 6 中的图像 2,3 How to Restring a French Horn: 步骤 6 中的图像 3,3
    • Wrap the string around the screw.
    • Tighten the screw.
  7. How to Restring a French Horn: 步骤 7 中的图像 1,3 How to Restring a French Horn: 步骤 7 中的图像 2,3 How to Restring a French Horn: 步骤 7 中的图像 3,3
    • Make sure your valve buttons are leveled, if it is too tight or to loose where it is not leveled, then you will have to repeat steps 1-6.
    • If your horn looks like any of these photos then congrats!! You are finished.
    • You may now move on with your day and go practice! Make sure to press the valve a coupe of times to make sure everything is secure well.
结论
Claudia aguilar
于04/16/24注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 21-21, Briggs Spring 2024 CSU Los Angeles, Team 21-21, Briggs Spring 2024 的会员
CSULA-BRIGGS-S24S21G21
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 45
总计 467
