跳转到主内容
How to Restore and Season a Cast Iron Pan
你所需要的
  1. How to Restore and Season a Cast Iron Pan, How to Restore and Season a Cast Iron Pan: 步骤 1 中的图像 1,1
    • Soak your pan in a roughly 50/50 mix of distilled white vinegar and water for about an hour.
    • You can wait longer if the rust is particularly bad.
  2. How to Restore and Season a Cast Iron Pan: 步骤 2 中的图像 1,1
    • Remove the pan from the vinegar solution.
    • Immediately apply baking soda to the pan to neutralize the acidity of the vinegar.
    • Start to wipe away the rust with steel wool.
  3. How to Restore and Season a Cast Iron Pan: 步骤 3 中的图像 1,1
    • Scour your pan inside and out with steel wool until either the rust or the white heat-damaged area appears black.
  4. How to Restore and Season a Cast Iron Pan: 步骤 4 中的图像 1,2 How to Restore and Season a Cast Iron Pan: 步骤 4 中的图像 2,2
    • Thoroughly dry your pan and place it over medium flame or in a 350 degrees Fahrenheit oven for 5 to ten minutes to allow it to completely dry.
  5. How to Restore and Season a Cast Iron Pan: 步骤 5 中的图像 1,3 How to Restore and Season a Cast Iron Pan: 步骤 5 中的图像 2,3 How to Restore and Season a Cast Iron Pan: 步骤 5 中的图像 3,3
    • Apply a generous amount of oil to the pan and rub it all over with a paper towel, making sure to hit every nook and cranny.
    • This process will remove the thin film of rust left by step 4.
  6. How to Restore and Season a Cast Iron Pan: 步骤 6 中的图像 1,1
    • Use a clean paper towel to thoroughly wipe off the pan.
  7. How to Restore and Season a Cast Iron Pan: 步骤 7 中的图像 1,2 How to Restore and Season a Cast Iron Pan: 步骤 7 中的图像 2,2
    • Repeat steps 5 and 6.
    • Place the pan upside down in an oven and turn it up to 500 degrees Fahrenheit or as high as it will go.
    • Once the oven reaches that temperature leave the pan in it for one hour.
  8. How to Restore and Season a Cast Iron Pan: 步骤 8 中的图像 1,1
    • Turn off the heat.
    • Allow the pan to cool naturally in the oven.
  9. How to Restore and Season a Cast Iron Pan: 步骤 9 中的图像 1,1
    • Your pan is now seasoned.
    • You may repeat steps 5-8 up to 6 times for higher quality results.
结论
You’re all done!
Mikhail Keyes
于06/14/21注册
219 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 41
总计 1,120
