跳转到主内容
How to Restore a Used Canvas
你所需要的
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: 步骤 1 中的图像 1,2 How to Restore a Used Canvas, How to Restore a Used Canvas: 步骤 1 中的图像 2,2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: 步骤 2 中的图像 1,2 How to Restore a Used Canvas: 步骤 2 中的图像 2,2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: 步骤 3 中的图像 1,1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: 步骤 4 中的图像 1,3 How to Restore a Used Canvas: 步骤 4 中的图像 2,3 How to Restore a Used Canvas: 步骤 4 中的图像 3,3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: 步骤 5 中的图像 1,1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: 步骤 6 中的图像 1,1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: 步骤 7 中的图像 1,3 How to Restore a Used Canvas: 步骤 7 中的图像 2,3 How to Restore a Used Canvas: 步骤 7 中的图像 3,3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: 步骤 8 中的图像 1,3 How to Restore a Used Canvas: 步骤 8 中的图像 2,3 How to Restore a Used Canvas: 步骤 8 中的图像 3,3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
终点
Sandra Henriquez
于04/21/21注册
157 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 775
