跳转到主内容
How to Restore a Torn Nike Flip-Flop
你所需要的
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: 步骤 1 中的图像 1,1
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: 步骤 2 中的图像 1,2 How to Restore a Torn Nike Flip-Flop: 步骤 2 中的图像 2,2
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: 步骤 3 中的图像 1,1
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: 步骤 4 中的图像 1,1
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: 步骤 5 中的图像 1,3 How to Restore a Torn Nike Flip-Flop: 步骤 5 中的图像 2,3 How to Restore a Torn Nike Flip-Flop: 步骤 5 中的图像 3,3
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: 步骤 6 中的图像 1,1
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
结论
The Nike Flip-Flop(s) are now restored and can be worn again.
7等其他人完成本指南。
Adrian Yearby
于07/12/17注册
265 声望
撰写一个指南
团队
Texas Tech, Team S1-G2, Rauch Summer 2017 Texas Tech, Team S1-G2, Rauch Summer 2017 的会员
TTU-RAUCH-SU17S1G2
2 名成员
创作了2篇指南
2条评论
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - 回复
Oh darn I see it now.lol
masood daud - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 70
过去 30 天: 343
总计 16,204
