跳转到主内容
How to Restore a Lace Frontal Wig
你所需要的
  1. How to Restore a Lace Frontal Wig, How to Restore a Lace Frontal Wig: 步骤 1 中的图像 1,2 How to Restore a Lace Frontal Wig, How to Restore a Lace Frontal Wig: 步骤 1 中的图像 2,2
    • Place your wig on the mannequin head and gently comb out the tangles starting from the ends all the way to the root before beginning the process.
  2. How to Restore a Lace Frontal Wig: 步骤 2 中的图像 1,1
    • Fill a large bowl with warm to hot water.
    • Add dish soap to create the soapy water to clean the residue out of the lace.
  3. How to Restore a Lace Frontal Wig: 步骤 3 中的图像 1,2 How to Restore a Lace Frontal Wig: 步骤 3 中的图像 2,2
    • Place ONLY the lace frontal portion of the unit into the soap water.
    • Allow it to soak for about 10-15 minutes.
    • After 10-15 minutes of soaking, there should be a distinct area where the adhesive residue is cleaned.
    • It will show up as a much lighter color and that indicates this is the residue that needs to be cleaned out of the lace.
  4. How to Restore a Lace Frontal Wig: 步骤 4 中的图像 1,3 How to Restore a Lace Frontal Wig: 步骤 4 中的图像 2,3 How to Restore a Lace Frontal Wig: 步骤 4 中的图像 3,3
    • Use a clean towel to gently rub the adhesive towards the edge of the lace to completely remove the adhesive.
    • GENTLY RUB or it can damage the lace (i.e. lace ripping, hair shedding out of lace, frontal balding).
    • After thoroughly rubbing the adhesive away, the lace should be completely clean of any residue and the wig unit is ready to be shampooed and conditioned.
  5. How to Restore a Lace Frontal Wig: 步骤 5 中的图像 1,1
    • Fully submerge the entire unit in lukewarm water to prep for shampoo.
  6. How to Restore a Lace Frontal Wig: 步骤 6 中的图像 1,2 How to Restore a Lace Frontal Wig: 步骤 6 中的图像 2,2
    • Squeeze shampoo across the root to the ends to have an even amount of shampoo to wash the unit.
    • Massage shampoo thoroughly through the entire unit.
    • Rinse entire unit to prep for conditioning.
    • Squeeze about pea size of conditioner into your finger tips.
    • Massage the conditioner into the ends of the unit and continue up throughout the unit up to the root.
    • Use a wide tooth comb or shower hair brush to distribute product evenly through the unit.
    • Rinse conditioner out of unit thoroughly.
  7. How to Restore a Lace Frontal Wig: 步骤 7 中的图像 1,1
    • Use a wide tooth comb or shower hair brush to detangle the unit again.
    • Use a heat protectant and blow dry or place the unit on a mannequin head to air dry.
    • For best results and to maintain the quality of the hair in the unit, allow it to air dry.
结论
If you ever need help with refreshing an old wig or a dirty wig, refer back to this guide
Celine Ajayi
于05/23/23注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 191
