跳转到主内容
How to Restore a Dented Hydro Flask
你所需要的
  1. How to Restore a Dented Hydro Flask, How to Restore a Dented Hydro Flask: 步骤 1 中的图像 1,1
    • Empty your Hydro Flask water bottle and clean the exterior.
    • You may want to remove stickers around the dent to see the damage more clearly.
  2. How to Restore a Dented Hydro Flask: 步骤 2 中的图像 1,1
    • Boil enough water to pour over the dent.
  3. How to Restore a Dented Hydro Flask: 步骤 3 中的图像 1,2 How to Restore a Dented Hydro Flask: 步骤 3 中的图像 2,2
    • Prepare an ice bath by filling a bin with water and ice in a small tub.
  4. How to Restore a Dented Hydro Flask: 步骤 4 中的图像 1,3 How to Restore a Dented Hydro Flask: 步骤 4 中的图像 2,3 How to Restore a Dented Hydro Flask: 步骤 4 中的图像 3,3
    • Place your Hydro Flask in an empty sink.
    • Pour the boiling water directly onto the dented area for about 10 seconds.
    • Boiling water can cause burns to the skin, protective gloves are suggested.
  5. How to Restore a Dented Hydro Flask: 步骤 5 中的图像 1,1
    • Immediately submerge the dented area into the prepared ice bath for about 10 seconds.
    • Handle the bottle with caution as it may still be hot from the previous step. Use protective gloves as suggested.
  6. How to Restore a Dented Hydro Flask: 步骤 6 中的图像 1,1
    • Use a wooden spoon to reach inside the Hydro Flask and push out the dent.
    • Any solid object long enough to reach the dent will also work.
结论
Madelyn
于01/26/23注册
133 声望
撰写一个指南
团队
UC Davis, Team 2-7, Morris Winter 2023 UC Davis, Team 2-7, Morris Winter 2023 的会员
UCD-MORRIS-W23S2G7
2 名成员
创作了6篇指南
一条评论
Ma con una borraccia termica(quindi a doppia parete) come si può fare?
Francesca Basile - 回复
添加评论
浏览统计数据:
过去 24 小时: 39
过去 7 天: 353
过去 30 天: 1,528
总计 15,151
