跳转到主内容
How to Restore a Damaged Cork Board
你所需要的
  1. How to Restore a Damaged Cork Board, How to Restore a Damaged Cork Board: 步骤 1 中的图像 1,1
    • Cover your work surface with a tarp.
  2. How to Restore a Damaged Cork Board: 步骤 2 中的图像 1,1
    • Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
    • Allow the area to dry.
  3. How to Restore a Damaged Cork Board: 步骤 3 中的图像 1,1
    • Apply wood filler liberally on top of the holes.
  4. How to Restore a Damaged Cork Board: 步骤 4 中的图像 1,2 How to Restore a Damaged Cork Board: 步骤 4 中的图像 2,2
    • Smooth out the wood filler using a putty knife.
    • Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
    • Wait 1 hour for the filler to dry.
  5. How to Restore a Damaged Cork Board: 步骤 5 中的图像 1,1
    • Use 80-grit sandpaper to sand down the excess filler in a circular motion.
  6. How to Restore a Damaged Cork Board: 步骤 6 中的图像 1,1
    • Cover the damaged area with a thin, even layer of wood sealant.
结论
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
另外一个人完成了本指南。
Annie Wilson
于09/27/23注册
154 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 101
总计 2,292
