跳转到主内容
How to Restore Tarnished Golf Shoe Spikes
你所需要的
  1. How to Restore Tarnished Golf Shoe Spikes, Golf Shoe Spikes: 步骤 1 中的图像 1,2 How to Restore Tarnished Golf Shoe Spikes, Golf Shoe Spikes: 步骤 1 中的图像 2,2
    • Take one of the golf shoes and place it so that the bottom of the shoe is facing upwards.
    • Use the Golf Utility Brush to remove any sort of dirt and debris from each individual golf shoe spike.
  2. How to Restore Tarnished Golf Shoe Spikes: 步骤 2 中的图像 1,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 2 中的图像 2,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 2 中的图像 3,3
    • Remove each golf shoe spike using the Softspikes Ripper Wrench by placing the wrench in the grooves of the spike and turning it counterclockwise.
  3. How to Restore Tarnished Golf Shoe Spikes: 步骤 3 中的图像 1,2 How to Restore Tarnished Golf Shoe Spikes: 步骤 3 中的图像 2,2
    • Using the Golf Utility Brush, clean the dirt and debris from the notch where the spike originally was. Repeat with all spike notches. This will make it easier to reattach the spikes later on.
  4. How to Restore Tarnished Golf Shoe Spikes: 步骤 4 中的图像 1,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 4 中的图像 2,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 4 中的图像 3,3
    • Place the spikes into a bowl containing two cups of water and four drops of dish soap.
    • Let the golf spikes soak in the bowl for 10 minutes before removing them.
  5. How to Restore Tarnished Golf Shoe Spikes: 步骤 5 中的图像 1,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 5 中的图像 2,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 5 中的图像 3,3
    • Lay each of the spikes out on a towel.
    • Use the Golf Utility Brush to clean the loosened dirt and debris from the side of the golf spike where the screw-in portion is.
    • Flip the golf spike over to the gripped side and scrub away any dirt remnants so that the golf spike is as clean as possible.
  6. How to Restore Tarnished Golf Shoe Spikes: 步骤 6 中的图像 1,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 6 中的图像 2,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 6 中的图像 3,3
    • Dry each golf spike with a towel by wrapping the towel around the golf spike and gently rubbing it in between your thumb and forefinger.
  7. How to Restore Tarnished Golf Shoe Spikes: 步骤 7 中的图像 1,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 7 中的图像 2,3 How to Restore Tarnished Golf Shoe Spikes: 步骤 7 中的图像 3,3
    • Reattach each of the golf spikes using the 2-Prong Insertion Wrench.
    • The wrench fits into two holes on the bottom of the spike. Turn the spike clockwise until you hear three clicks, signaling the golf spike is properly inserted. Refer to the image if there is any confusion.
结论
Once all of the spikes are reinserted, repeat the whole process with the second shoe.
一条评论
Is there anyway to fix the insert the spike fits into? I keep losing spikes daily
Eric Wolfert - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 42
总计 1,648
