跳转到主内容
How to Restore Jordan Midsoles
你所需要的
  1. How to Restore Jordan Midsoles, How to Restore Jordan Midsoles: 步骤 1 中的图像 1,1
    • Grab the pair of Jordans you would like to repaint and wipe the midsole with a toothbrush or cotton ball to remove any dirt or dust (midsoles are already clean in this picture).
  2. How to Restore Jordan Midsoles: 步骤 2 中的图像 1,1
    • Using a metal file, carefully scratch off the paint closest to the leather.
  3. How to Restore Jordan Midsoles: 步骤 3 中的图像 1,1
    • Wet a cotton ball with acetone and lightly scrub the leftover paint until the surface is smooth and most or all the paint is removed.
    • I recommend using rubber gloves to protect your skin from the acetone, but it's not necessary.
  4. How to Restore Jordan Midsoles: 步骤 4 中的图像 1,1
    • Remove any dust, dirt, and excess paint with your fingers or cotton balls and water.
  5. How to Restore Jordan Midsoles: 步骤 5 中的图像 1,1
    • Carefully place painter's tape along the edges of the part of the shoe you would like to paint.
  6. How to Restore Jordan Midsoles: 步骤 6 中的图像 1,3 How to Restore Jordan Midsoles: 步骤 6 中的图像 2,3 How to Restore Jordan Midsoles: 步骤 6 中的图像 3,3
    • Grab your paint and paint brush and thinly coat the desired area.
  7. How to Restore Jordan Midsoles: 步骤 7 中的图像 1,1
    • Wait until your paint dries and apply another coat. Repeat this step 2-4 more times or until you're content with the shade of your color. This picture depicts the shade of white after 5 coats.
    • For best results, wait 24 hours between each paint coat.
  8. How to Restore Jordan Midsoles: 步骤 8 中的图像 1,3 How to Restore Jordan Midsoles: 步骤 8 中的图像 2,3 How to Restore Jordan Midsoles: 步骤 8 中的图像 3,3
    • After applying your final coat, allow 24-48 hours for the paint to dry before wearing. Once your paint is dry, remove the tape and you're good to go!
终点
16等其他人完成本指南。
Kevin Wong
于09/29/15注册
761 声望
撰写一个指南
团队
Cal Poly, Team 17-6, Green Fall 2015 Cal Poly, Team 17-6, Green Fall 2015 的会员
CPSU-GREEN-F15S17G6
3 名成员
创作了1篇指南
3指南评论
this is a really bad explanation. You should get a life, because you clearly suck at this
William Roberts - 回复
100%. I think he’s confused about what restoring means. Putting in a little paint in no way is restoring
Albert Shoestein -
I just finished my first pair of restored J’s by following the OP instructions. It does take some time and precision work, and patience, but just WOW my Jordans look brand new! (I created a profile but for some reason I can’t log in, ..?) Thanks again OP for this awesome and easy to follow tutorial!
Inigo Montoya - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 71
总计 29,978
