简介
During normal use, headlights are exposed to UV light, dirt, chemicals, and water vapor, causing their plastic housing to oxidize and deteriorate, making the headlight foggy and potentially reducing visibility by up to 50%. While this guide demonstrates the headlight restoration on a 2003 GMC Envoy, these steps will bring any foggy headlights back to like-new conditions.
Before beginning, make sure that rain or other precipitation isn't expected in your area for the next couple days, or that you have a well-ventilated garage or covered space to work in; excessive moisture will disrupt the clear coat as it cures.
你所需要的
Place masking tape around the perimeter of the headlights to protect your vehicle's paint.
Use wet 1000 grit sandpaper and light pressure to sand the plastic in circular patterns. When you notice that the small scratches look identical across the entire headlight, sand horizontally until all the small scratches appear horizontal.
Repeat the process with 1500, then 2000 grit sandpaper.
Enjoy your crystal-clear headlights!
18等其他人完成本指南。
2指南评论
Thank you it is very much clear to understand.
Excelente, muy sencillo y practico, ademas funciona!
