跳转到主内容
How to Restore Dried Clay
你所需要的
  1. How to Restore Dried Clay, How to Restore Dried Clay: 步骤 1 中的图像 1,1
    • Break apart the dried clay into small pieces using a hard sturdy object, such as a mallet or a dull metal knife.
    • Smaller pieces will help the clay soften quicker.
  2. How to Restore Dried Clay: 步骤 2 中的图像 1,1
    • Pour water into a container large enough for the clay you are restoring.
  3. How to Restore Dried Clay: 步骤 3 中的图像 1,1
    • Add the broken clay to water.
    • Make sure the clay is completely covered in the water. This will help keep the clay texture smooth.
  4. How to Restore Dried Clay: 步骤 4 中的图像 1,1
    • Soak the clay in water overnight for 24 hours.
    • The clay will become very soft and mushy.
  5. How to Restore Dried Clay: 步骤 5 中的图像 1,2 How to Restore Dried Clay: 步骤 5 中的图像 2,2
    • Put on gloves to keep your hands clean.
  6. How to Restore Dried Clay: 步骤 6 中的图像 1,1
    • Place a plastic bag or plastic wrap on your working surface.
    • This helps keep your working surface and your clay clean.
  7. How to Restore Dried Clay: 步骤 7 中的图像 1,1
    • Scoop out the softened clay from your container and place it on the plastic.
    • Use both hands to scoop the clay, then scrape it off your hands and onto the plastic sheet.
  8. How to Restore Dried Clay: 步骤 8 中的图像 1,1
    • Use your hand to flatten and spread the clay out on the plastic.
    • Use both hands to scrape off any clay that sticks to your gloves.
  9. How to Restore Dried Clay: 步骤 9 中的图像 1,1
    • Let your clay sit for a day until it is soft to the touch and no longer sticking to your fingers.
    • The thinner/more spread out the clay, the faster it will dry.
    • Check on clay every few hours to make sure it doesn't dry out completely.
  10. How to Restore Dried Clay: 步骤 10 中的图像 1,1
    • Knead the clay by massaging it with your hands. Continue until the clay is combined.
    • You can also push and press the clay against your working surface to combine it.
  11. How to Restore Dried Clay: 步骤 11 中的图像 1,3 How to Restore Dried Clay: 步骤 11 中的图像 2,3 How to Restore Dried Clay: 步骤 11 中的图像 3,3
    • Tightly wrap your clay in plastic wrap to make sure it doesn't dry up again.
    • Avoid air bubbles by pressing the plastic wrap against the surface of the clay.
结论
Keep your clay tightly wrapped up or placed within an air tight container to keep it from drying out again. Adding water onto the clay also helps to keep it soft and manageable.
2等其他人完成本指南。
Moss
于04/26/24注册
223 声望
撰写一个指南
团队
UC Davis, Team 4-7, Whithaus Spring 2024 UC Davis, Team 4-7, Whithaus Spring 2024 的会员
UCD-WHITHAUS-S24S4G7
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 158
