跳转到主内容
How to Restore An Expo Marker
你所需要的
  1. How to Restore  An Expo Marker, How to Restore  An Expo Marker: 步骤 1 中的图像 1,1
    • Collect all of the markers you want to restore.
    • Obtain isopropyl alcohol (rubbing alcohol) or vinegar.
  2. How to Restore  An Expo Marker: 步骤 2 中的图像 1,1
    • Pour a small amount of either alcohol or vinegar into a small bowl, using enough to cover the tip of the markers.
    • Soak the tip of the markers in the alcohol or vinegar until the ink comes out of the tip of the marker.
    • In some cases, you will see the ink of the marker swirl out.
  3. How to Restore  An Expo Marker: 步骤 3 中的图像 1,2 How to Restore  An Expo Marker: 步骤 3 中的图像 2,2
    • Place the cap back on the marker.
    • Let the marker sit tip side up for at least 24 hours. The alcohol should penetrate inside the tip of the marker.
  4. How to Restore  An Expo Marker: 步骤 4 中的图像 1,1
    • Your marker should be good to go.
    • If your marker is not functioning properly, it may be a sign that your marker dried out completely.
结论
5等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 59
过去 30 天: 307
总计 47,132
