跳转到主内容
How to Resize Pants
你所需要的
  1. How to Resize Pants, How to Resize Pants: 步骤 1 中的图像 1,1
    • Put on the pants inside out.
  2. How to Resize Pants: 步骤 2 中的图像 1,1
    • Safety pin the waistband of the pants to the desired fit.
  3. How to Resize Pants: 步骤 3 中的图像 1,1
    • Pin the outside seam around both hips so that the pants are snug.
  4. How to Resize Pants: 步骤 4 中的图像 1,2 How to Resize Pants: 步骤 4 中的图像 2,2
    • Pin down the back seam and inseam so that the pants fit comfortably.
  5. How to Resize Pants: 步骤 5 中的图像 1,1
    • Take the pants off. Sew the back seam, following your pins.
    • Be careful when operating a sewing machine.
  6. How to Resize Pants: 步骤 6 中的图像 1,1
    • Put the pants on. Pin the rest of the inseam and the outside seam down both legs.
    • Our preference was to use the skinny jean cut. However, this sewing technique can be applied to any jean cut by simply adjusting the snugness of the fit as you pin.
  7. How to Resize Pants: 步骤 7 中的图像 1,1
    • Take the pants off. Then, cut off the extra fabric.
    • If you prefer, iron your newly created seams so that they lay open.
  8. How to Resize Pants: 步骤 8 中的图像 1,1
    • Enjoy your newly fitted pair of pants!
结论
After following these steps, you should have properly fitting pants that were ill-fitting before.
23等其他人完成本指南。
团队
5指南评论
Thank you for this! I have a pair I really like that are huge in the hip and butt. So is it best to pin and make them fit better using the inseam, or the outside seam?
Matt and Amy Crowell - 回复
Thank you, I used your guide for my first time fitting pants; it was absolutely helpful!
Angelica Murillo - 回复
Muy original y más fácil de lo que había visto. A pesar que me defiendo bastante bien con la costura, esto de cambiar de una talla XL a una S, no lo hice nunca en un short, así que gracias por compartir tus conocimientos.
Ros CH - 回复
para que no se deshilen los bordes hay que darle unas puntadas en forma de zig zag a todos los bordes que se cortan.
DAVID MORENO - 回复
This guide is super helpful for resizing pants! Clear steps and easy-to-follow instructions. Thanks!
fundtaffrail - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 56
过去 30 天: 285
总计 143,111
