跳转到主内容
How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
你所需要的
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 1 中的图像 1,2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 1 中的图像 2,2
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 2 中的图像 1,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 2 中的图像 2,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 2 中的图像 3,3
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 3 中的图像 1,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 3 中的图像 2,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 3 中的图像 3,3
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 4 中的图像 1,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 4 中的图像 2,3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 4 中的图像 3,3
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: 步骤 5 中的图像 1,1
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 21
过去 30 天: 57
总计 3,297
