跳转到主内容
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
你所需要的
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 2 中的图像 1,3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 2 中的图像 2,3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 2 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 3 中的图像 1,3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 3 中的图像 2,3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 3 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 4 中的图像 1,2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 4 中的图像 2,2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 5 中的图像 1,1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: 步骤 6 中的图像 1,1
    • Insert battery back into position with the flat side facing upwards.
结论
2等其他人完成本指南。
Andrew Barsoom
于01/17/21注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 138
总计 4,660
