简介
如果您忘记了电脑的登录密码,或者想要让您的设备焕然一新,您可以在“疑难解答”页面中对设备进行重置。
重要提示:重置将导致您设备的设置恢复到出厂状态。
访问以下链接查看操作视频(需要网络环境):
视频概述
在菜单中选择:
疑难解答
重置电脑
Bei TrakStore ist nur “Neustarten” möglich. Das Tablet arbeitet dann aber genauso, wie als würde “Reset” angezeigt. Deutsche Spracheinstellung.
I want to reset the color in this tablet now please
Set the color in this tablet please
What if I get to this point and my laptop freezes and won't allow me to go any further?
跟随提示重置您的设备。
Did you ever get an answer to your tablet issue?
This method didn't work it still asks for the password before allowing you to reset or restore… what else you got?
Has anyone figured out how to get past step 4? My touchscreen wont let me select next or cancel. I've tried to use a keyboard and same results. ???????
Exaxtly the same happend to me…..I-ONIK TW-8
Geh -
Additional free space is needed on the drive where windows is installed. Free up some space and try again.
What should I do now please help?
这将把您的设备重置为出厂状态。
这就是全部的步骤,你学会了吗?
Thank you so much!! I’ve been scouring the internet trying to reset my POS Walmart tablet and this is what finally worked!
Mine seems to get stuck on step 4 I have the 2 options run and close but they are blanked out cannot go any further
I am too experiencing the same problem with my Asus tablet. Have you managed to fix it? I also need help.
Me too with my acre tablet
But I don't want to loose my data (like photos & other files). Please suggest.
thanks alot is working
Mohsin Ali - 回复
Displayed after restarting after trouble shooting said PC was shut down incorrect and said something about firm ware and a windows kwy
Hi there, Can you help me to fix my tablet-pc?
I reseted it one time but as it was supposed to install Windows, it keeps on rebooting again & again no change in the installation.
Wow thanks that was easy
I get stuck on “additional space is needed where Windows installed.”
E. Serrano - 回复
I forgot my password and i reinstall new windows 10 and my touch, volume,and the camera are not working again please I need help thanks
Mine ends up with instructions warning of clearing a trust area and asks me to either press F12 or Esc or volume up and down buttons But no method for input?
Merci infiniment
Thank you too :)
ZFix -
Merci pour tout
Néanmoins moi j'ai tablette pc winpad 10 après réinitialisation ça s'est arrêté à 66% ce qui bloque l'allumage du tablette a nouveau.
Comment il faut procéder pour récupérer ma tablette
Did not work on ROTOR tablet (without integrated keyboard) - at some point the crap tablet entered EFI shell - and does not react on external keyboard. Now - stuck in EFI shell. Only wanted to restore original windows setting, as one of the windows updates resulted in a non-working on-screen-keyboard (and also refusing external keyboard) after logging in...
要重新开始使用您的设备,只需按照相反顺序阅读本指南。
34等其他人完成本指南。
由衷感谢以下译者:
100%
初心不变_叶子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
25条评论
thankz for help
Hi, did you know how to fix Windows tablet stuck in boot? It said that “no bootable device found “. Tablet brand and model : Vulcan Journey.
It started after I erase/format the tablet because I forgot the password.
Thanks
Hello. I have a MPMan with Win 10 installed and the touchscreen does not work anymore.
I'm going to install win 8.1 on it .... win 8.1 was out of production. thank you very much
while i am reset final step erase everything touch not in work how to fix?
having same problom touch doesent qwork at reset part
lachjul -
iam using linx its good
I I appreciated it helps very well thanks
I get to step 4 but the buttons are blank and i can go no further
Hi, am using speedstar windows tablet after reseting the screen didn’t touch and windows cannot be loaded, what can i do.
ekaso
Hello to everyone,
Me to it stock at reinstall your pc, cannot press next.
I HAVE A WINDOW DUST, DIJ4100BK132..
If anybody as a solution or another technique to do. PLEASE.
Thank you.
I followed the instructions to restore my linx tablet to factory settings but a blue screen came up with a bar code what do i do now
My avgo tablet has gone to auto repair and I am trying to reset it to its factory . the problem to it is that it needs to be reinstalled to its windows 10 and i bought a 32gb memory stick in order to store backup , so i can use the usb to transfer the files to my avgo. what else can i do its getting frustrated.
Hello, do u no how to reset the Tablet pc model no: "TL10IE2" Intel education solutions
oluwasusif - 回复
Merci mec du fond du coeur.???
Buongiorno ho un tablet dell' Windows ma c'è la password di un altra persona come faccio per fare un mio account nuovo
How do I reset the westgate resort pivot tablet? I've tried to manually hard factory reset but it still doesn't work or just freezes on the start up screen
bonjour
merci pour le tuto, j etais bloqué sur un mot de passe oublié ,le votre m a permis de remettre mon petit ordi
en fonctionnement
encore merci
When I reset, the device prompts "Additional free space is needed where Windows is installed. Free up some space and try again"
Any ideas on how to bypass this issue?
nyron_mohd - 回复
wow c est très magnifique
