跳转到主内容
How to Repress a Broken Makeup Compact
你所需要的
  1. How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: 步骤 1 中的图像 1,2 How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: 步骤 1 中的图像 2,2
    • If some of the product remains unbroken, break it down using a toothpick . Completely crush the powder for a smooth fix.
  2. How to Repress a Broken Makeup Compact: 步骤 2 中的图像 1,2 How to Repress a Broken Makeup Compact: 步骤 2 中的图像 2,2
    • Add a few drops of rubbing alcohol to the broken product (the amount differs based on how much product you have left) and then thoroughly mix the alcohol into the powder with a toothpick.
  3. How to Repress a Broken Makeup Compact: 步骤 3 中的图像 1,1
    • Place plastic wrap over the product and pull taut to reduce wrinkles in the plastic wrap.
  4. How to Repress a Broken Makeup Compact: 步骤 4 中的图像 1,2 How to Repress a Broken Makeup Compact: 步骤 4 中的图像 2,2
    • Press and smooth the product out using your finger or a spoon.
    • This may take some patience depending on how smooth you would like your product to turn out.
  5. How to Repress a Broken Makeup Compact: 步骤 5 中的图像 1,1
    • Once smoothed, remove the plastic wrap and allow the compact to dry for 6-8 hours.
    • Pro tip: If you need to use your product soon, you can speed up drying time by using a hairdryer on low heat!
  6. How to Repress a Broken Makeup Compact: 步骤 6 中的图像 1,2 How to Repress a Broken Makeup Compact: 步骤 6 中的图像 2,2
    • Lastly, enjoy your product! It provides the same pigment and performance as it once did before the break.
结论
This method will save you money and preserve your favorite powder products without compromising its quality or pigment. I hope you found my guide useful.
Your friendly makeup lover,
Alexis
2等其他人完成本指南。
Alexis Wilhelm
于05/01/20注册
181 声望
撰写一个指南
团队
UW Tacoma, Team S1-G49, Cardinal Spring 2020 UW Tacoma, Team S1-G49, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G49
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 49
总计 3,737
