跳转到主内容
How to Repot an Overgrown Monstera
你所需要的
  1. How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: 步骤 1 中的图像 1,3 How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: 步骤 1 中的图像 2,3 How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: 步骤 1 中的图像 3,3
    • Prepare the new pot by filling it around a third full with fresh potting soil.
    • Place the support stake in the desired location so the stake hits the bottom of the pot.
  2. How to Repot an Overgrown Monstera: 步骤 2 中的图像 1,1
    • Tip the Monstera slowly onto its side and lift the roots sideways out of the old pot.
    • Support the roots and branches when transferring, and ensure not to break them.
  3. How to Repot an Overgrown Monstera: 步骤 3 中的图像 1,1
    • Loosen and remove old soil from the root ball by gently massaging it away from the roots with your fingers.
  4. How to Repot an Overgrown Monstera: 步骤 4 中的图像 1,2 How to Repot an Overgrown Monstera: 步骤 4 中的图像 2,2
    • Place the root ball in the new pot and place fresh soil around the root ball.
    • Leave an inch or two of space between the soil and the top of the pot.
  5. How to Repot an Overgrown Monstera: 步骤 5 中的图像 1,1
    • Adjust the roots and leaves around the stake.
    • Direct any long aerial roots back toward the soil as you adjust the plant in the soil.
  6. How to Repot an Overgrown Monstera: 步骤 6 中的图像 1,1
    • Tie the stems of the monstera up and down the stake to obtain even support and keep it upright.
    • Be careful not to break any leaves or stems by tying the plant to the stake too tightly.
  7. How to Repot an Overgrown Monstera: 步骤 7 中的图像 1,1
    • Water the monstera well; the plant is properly saturated when water runs out of the holes in the bottom of the pot.
    • Water the plant over a trash bag or something that will catch the excess water.
结论
In all, this is an easy at-home fix to keep a monstera plant healthy. This fix guides the user to remove and re-plant the monstera, and to water it at the end. We advise continued plant care and watering after repotting.
Owen Chen
于11/05/24注册
145 声望
撰写一个指南
团队
UC Davis, Team 1-7, Vidal-Chiesa Fall 2024 UC Davis, Team 1-7, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S1G7
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 144
