跳转到主内容
How to Repot a Dying Plant
你所需要的
  1. How to Repot a Dying Plant, How to Repot a Dying Plant: 步骤 1 中的图像 1,2 How to Repot a Dying Plant, How to Repot a Dying Plant: 步骤 1 中的图像 2,2
    • Remove the entire plant from its previous pot by grasping the plant at the base of the stem and gently removing the soil and dead plant material from the plant roots with your fingers.
    • Warning: Be cautious not to break any living roots while removing the soil.
  2. How to Repot a Dying Plant: 步骤 2 中的图像 1,2 How to Repot a Dying Plant: 步骤 2 中的图像 2,2
    • Place only the roots in the hydrogen peroxide/water mixture to soak.
  3. How to Repot a Dying Plant: 步骤 3 中的图像 1,1
    • Cover the bottom of the new pot with small rocks to ensure proper soil drainage.
    • Tip: Make sure the rocks are not too big as they may stop water from draining out.
  4. How to Repot a Dying Plant: 步骤 4 中的图像 1,2 How to Repot a Dying Plant: 步骤 4 中的图像 2,2
    • Fill the new pot halfway with fresh potting soil.
  5. How to Repot a Dying Plant: 步骤 5 中的图像 1,1
    • Press a small hole into the top of the soil.
    • Tip: The hole should not go deeper than the roots of the plant.
  6. How to Repot a Dying Plant: 步骤 6 中的图像 1,2 How to Repot a Dying Plant: 步骤 6 中的图像 2,2
    • Place the plant roots-first in the hole and gently push the surrounding soil over them. If necessary, fill in the sides around the plant base with soil for stability.
    • Warning: Do not press down on the soil as this can decrease the drainage capacity.
结论
Your plant should thrive now that it is able to extend its roots in a larger pot. Proper care and sunlight will ensure your plant lives a long and healthy life, however, these steps can be repeated in the future if necessary.
2等其他人完成本指南。
Bria Bynum
于10/26/21注册
139 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 30
总计 2,192
