跳转到主内容
How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
你所需要的
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: 步骤 1 中的图像 1,2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: 步骤 1 中的图像 2,2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 2 中的图像 1,1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 3 中的图像 1,1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 4 中的图像 1,1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 5 中的图像 1,1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 6 中的图像 1,2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: 步骤 6 中的图像 2,2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
终点
另外一个人完成了本指南。
Pearce McKee
于03/31/20注册
133 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 69
总计 1,344
