跳转到主内容
How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla
你所需要的
  1. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: 步骤 1 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla, Wiper Arm: 步骤 1 中的图像 2,2
    • Take the tip of your flathead screwdriver, and wedge it underneath the wiper cap.
    • Firmly pry the wiper cap upwards until it's completely off.
  2. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 2 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 2 中的图像 2,2
    • Place the head of your ratchet on the exposed nut.
    • Loosen the nut by turning your ratchet counter clockwise.
  3. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 3 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 3 中的图像 2,2
    • Once the nut is loose enough, you may grab it and place it to the side.
  4. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 4 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 4 中的图像 2,2
    • Firmly grip the lower end of the wiper arm.
    • Pull it towards you, so that the wiper arm is extended in the upward position.
  5. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 5 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 5 中的图像 2,2
    • While holding the lower end of the wiper arm, tug the wiper arm upwards until completely detached.
    • Don't be discouraged if the wiper arm isn't detached right away. You may have to tug upwards a few times to detach it.
  6. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 6 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 6 中的图像 2,2
    • Have your new wiper arm extended in the upward position (just how your old wiper arm was extended at the end of Step 4).
    • Take your wiper arm, and center its hole on the exposed metal threading.
  7. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 7 中的图像 1,2 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 7 中的图像 2,2
    • Once the wiper arm has been placed onto the metal threading, firmly grip the lower end of the wiper arm.
    • Slowly push the wiper arm downwards and away from you, so that it's flat with the windshield.
    • Make sure to do this slowly so that your fingers are not compressed by the wiper arm and the windshield.
  8. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 8 中的图像 1,3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 8 中的图像 2,3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 8 中的图像 3,3
    • Place the same nut from earlier onto the exposed threaded metal.
    • Place the head of your ratchet onto the nut.
    • Tighten the nut by turning your ratchet clockwise, until it can no longer be tightened.
  9. How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 9 中的图像 1,3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 9 中的图像 2,3 How to Replace the Wiper Arm(s) of a 2005 Toyota Corolla: 步骤 9 中的图像 3,3
    • Firmly press the wiper cap upon the exposed nut.
    • Once the wiper cap is secure, you may repeat steps 1-9 to the other wiper arm.
结论
Once you have replaced one of your wiper arms, repeat the same process for the remaining wiper arm.
4等其他人完成本指南。
团队
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015 的会员
CPSU-GREEN-F15S15G2
4 名成员
创作了4篇指南
一条评论
good merci
thank you
Moad Mezzari - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 67
总计 9,444
