跳转到主内容
How to Replace the Temple Tips of a Pair of Eyeglasses
你所需要的
  1. How to Replace the Temple Tips of a Pair of Eyeglasses, Temple Tip: 步骤 1 中的图像 1,1
    • Put all separated parts of the eyeglass including the eyeglass frame, temple tip on a clean and flat surface.
  2. How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 2 中的图像 1,2 How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 2 中的图像 2,2
    • Clean the temple and temple tip with alcohol wipes to make sure any glue residue is removed.
  3. How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 3 中的图像 1,1
    • Drop a single drop of glue onto the end of the temple tip.
  4. How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 4 中的图像 1,2 How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 4 中的图像 2,2
    • Slide the temple tip into the end of the metal part of the eyeglass temple until you feel the metal part hits the bottom of the temple tip.
  5. How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 5 中的图像 1,1
    • Hold it together for around one minute to keep it in the correction position.
  6. How to Replace the Temple Tips of a Pair of Eyeglasses: 步骤 6 中的图像 1,1
    • Using a hairdryer on high heat, heat the temple tip to shrink it for roughly 3-6 minutes.
    • For safety, wear thick gloves during this step. It can protect you from burning your hand by the hot air of the hairdryer.
结论
Fixing a temple tip of eyeglasses is an uncomplicated process that you can do at home by yourself. Our instruction will have some steps, following:
2等其他人完成本指南。
ZHEHAO GUO
于01/19/21注册
187 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 92
过去 30 天: 396
总计 12,947
