跳转到主内容
How to Replace the Rear Wheel of a Segway Ninebot ES4
你所需要的
  1. How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: 步骤 1 中的图像 1,3 How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: 步骤 1 中的图像 2,3 How to Replace the Rear Wheel of a Segway Ninebot ES4, Segway Ninebot ES4 Rear Wheel: 步骤 1 中的图像 3,3
    • Place the scooter on its side and locate the two access screw holes.
    • Use a flathead screwdriver to remove the protective inserts.
  2. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 2 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 2 中的图像 2,2
    • Use a 3/32" hex key wrench to remove the screws that are securing the rear casing.
  3. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 3 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 3 中的图像 2,2
    • Remove the rear casing and disconnect the rear light power cable.
    • Reposition the scooter to allow access to the opposite side. Then, repeat steps 1-3 to expose both sides of the rear wheel.
  4. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 4 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 4 中的图像 2,2
    • Use a T25 star screwdriver on each side to remove the screw securing the axle.
  5. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 5 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 5 中的图像 2,2
    • Insert a screwdriver into the hole where the screw was removed.
    • Use it to push the axle out from the opposite side.
  6. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 6 中的图像 1,3 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 6 中的图像 2,3 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 6 中的图像 3,3
    • Locate the rear wheel replacement.
    • Insert the axle into the scooter's rear axle housing.
    • Once the axle is in place, position the replacement wheel onto the axle while it is inside the scooter.
    • Ensure that the arrow-like grip pattern on the wheel points toward the front of the scooter.
  7. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 7 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 7 中的图像 2,2
    • Place the star screw on the side opposite to where the axle was inserted.
    • Use a T25 star screwdriver on each side to tighten and secure the rear axle.
  8. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 8 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 8 中的图像 2,2
    • Before reinstalling the rear casing, connect the rear light power cable.
    • Ensure you line up the connection points so the small protrusion pairs with the corresponding hole.
  9. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 9 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 9 中的图像 2,2
    • After connecting the cable, reinstall the rear casing.
    • The cable should pass underneath the circled protrusion when installed.
  10. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 10 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 10 中的图像 2,2
    • Use a 3/32" hex key wrench to install the screws that secure the rear casing.
  11. How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 11 中的图像 1,2 How to Replace the Rear Wheel of a Segway Ninebot ES4: 步骤 11 中的图像 2,2
    • Place the protective inserts back inside the screw holes.
    • Reposition the scooter to allow access to the opposite side. Then, repeat steps 8-11.
结论
With that, you've replaced the rear wheel of your Segway Ninebot ES4! Happy scootering!
另外一个人完成了本指南。
Dylan Huang
于10/23/23注册
194 声望
撰写一个指南
团队
CSU Los Angeles, Team 3-58, Briggs Fall 2023 CSU Los Angeles, Team 3-58, Briggs Fall 2023 的会员
CSULA-BRIGGS-F23S3G58
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 881
