跳转到主内容
How to Replace the Net on a Basketball Hoop
你所需要的
  1. How to Replace the Net on a Basketball Hoop, Net: 步骤 1 中的图像 1,1
    • Set up a ladder below the basketball rim.
    • Make sure the ladder is steady and placed on a level surface.
  2. How to Replace the Net on a Basketball Hoop: 步骤 2 中的图像 1,3 How to Replace the Net on a Basketball Hoop: 步骤 2 中的图像 2,3 How to Replace the Net on a Basketball Hoop: 步骤 2 中的图像 3,3
    • Loop the first net loop through the basketball rim.
    • Push the net through each loop on the basketball rim.
    • Pull the net loop down and spread the rope across the rim coil as shown
    • Pull the net tightly to the rim.
  3. How to Replace the Net on a Basketball Hoop: 步骤 3 中的图像 1,1
    • Using the same technique from step 2, loop the remaining net loops around the rim.
  4. How to Replace the Net on a Basketball Hoop: 步骤 4 中的图像 1,1
    • Test the net and remove any wrinkles by pulling down on the bottom of the net.
  5. How to Replace the Net on a Basketball Hoop: 步骤 5 中的图像 1,1
    • Step down from the ladder and play ball.
    Come si fa quando i canestri non hanno gli occhielli a spirale, ma sono degli anelli chiusi?
    Seric - 回复
结论
Now that you've replaced your net, you're ready play some basketball.
3等其他人完成本指南。
Kevin A Walker
于02/24/15注册
164 声望
撰写一个指南
团队
Cal Poly, Team 23-3, Green Winter 2015 Cal Poly, Team 23-3, Green Winter 2015 的会员
CPSU-GREEN-W15S23G3
6 名成员
创作了13篇指南
3条评论
Thanks for letting my grandchildren help me from the Basketball Net. Your truly Kelly
akiborja1017 - 回复
i don't have these things were I can like put the net in
leon reichert - 回复
do you mean they dont have the little hooks that the net latches on to onto the hoop?
tayola -
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 190
过去 30 天: 939
总计 109,247
