跳转到主内容
加入维修社区 - 创建账户
How to Replace the Key Fob Battery in a 2018 BMW 330i
浏览量: 2998
浏览统计数据:
过去24小时
9
过去 7 天:
72
过去 30 天:
315
总计
2,998
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 2
2 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 1 - 2 分钟
难度: 非常容易
If your 2018 BMW 330i key fob has stopped working or has a weak signal, the battery is likely dead. Instead of going to a dealership and paying for a replacement, you can easily swap out the battery yourself in just a few minutes.
This guide will walk you through the step-by-step process of opening the key fob, replacing the battery, and reassembling it correctly. The process is simple, requires only a small flathead screwdriver, and will help you restore full key fob functionality.
你所需要的
配件
工具
  • Spudger
    4.9
    选填
    1. How to Replace the Key Fob Battery in a 2018 BMW 330i, Key Fob Battery: 步骤 1 中的图像 1,2 How to Replace the Key Fob Battery in a 2018 BMW 330i, Key Fob Battery: 步骤 1 中的图像 2,2
      • Press the small button on the back of the key fob to release the mechanical key.
      • Pull the key out completely.
      询问修复机器人
      添加评论
    2. How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 2 中的图像 1,1
      • Insert the mechanical key into the slot and gently twist it to pry open the key fob case.
      • Be careful not to use excessive force, as this may damage the plastic casing.
      询问修复机器人
      添加评论
    3. How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 3 中的图像 1,2 How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 3 中的图像 2,2
      • Once the key fob is open, you will see the CR2450 battery inside. Make a note of its positive (+) and negative (-) orientation.
      • Carefully remove the old CR2450 battery by lifting it out with a nylon spudger or your fingernail.
      • Avoid using sharp metal tools to prevent damage to the battery compartment.
      询问修复机器人
      添加评论
    4. How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 4 中的图像 1,3 How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 4 中的图像 2,3 How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 4 中的图像 3,3
      • Place the new CR2450 battery in the correct orientation, with the positive (+) side facing up.
      • Ensure the battery is properly seated in the battery slot.
      • Double-check that the battery is positioned correctly before closing the key fob.
      询问修复机器人
      添加评论
    5. How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 5 中的图像 1,1
      • Align the two halves of the key fob and press them firmly together until you hear a click.
      • Ensure all edges are securely snapped back into place.
      询问修复机器人
      添加评论
    6. How to Replace the Key Fob Battery in a 2018 BMW 330i: 步骤 6 中的图像 1,1
      • Slide the mechanical key back into the key fob until it locks into place.
      • Press the lock/unlock buttons to ensure the key fob is working.
      • If the key fob does not respond, recheck the battery installation to ensure it is properly seated.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 72
过去 30 天: 315
总计 2,998
