跳转到主内容
How to Replace the Fishing Line of a Spinning Reel
你所需要的
  1. How to Replace the Fishing Line of a Spinning Reel, Fishing Line: 步骤 1 中的图像 1,1
    • Find the recommended line weights on the side of the reel and purchase the specified line.
    • The side of this reel reads lbs/yrds 6/390, 8/320, or 10,200 so use 6, 8, or 10 pound fishing line.
  2. How to Replace the Fishing Line of a Spinning Reel: 步骤 2 中的图像 1,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 2 中的图像 2,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 2 中的图像 3,3
    • Flip up the metal bail on the spinning reel.
    • Remove the old line by pulling it off the top of the reel.
  3. How to Replace the Fishing Line of a Spinning Reel: 步骤 3 中的图像 1,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 3 中的图像 2,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 3 中的图像 3,3
    • Feed the end of the new line through the first eyelet of the fishing rod.
    • Tie a single overhand knot towards the end of the line.
  4. How to Replace the Fishing Line of a Spinning Reel: 步骤 4 中的图像 1,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 4 中的图像 2,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 4 中的图像 3,3
    • With the bail still up, wrap the line around the reel and tie a double overhand knot.
    • Tighten the line up to the first knot made in the previous step.
  5. How to Replace the Fishing Line of a Spinning Reel: 步骤 5 中的图像 1,1
    • Use utility scissors to clip the excess line near the base of the reel.
  6. How to Replace the Fishing Line of a Spinning Reel: 步骤 6 中的图像 1,1
    • Place the new spool so it is facing up to prevent line twist.
  7. How to Replace the Fishing Line of a Spinning Reel: 步骤 7 中的图像 1,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 7 中的图像 2,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 7 中的图像 3,3
    • Flip the bail down and slowly reel the line, keeping light tension using your finger.
    • Continue reeling until there is roughly an 1/8th of an inch of radial space left on the reel.
    • Do not overfill the reel with line. This may cause tangles.
  8. How to Replace the Fishing Line of a Spinning Reel: 步骤 8 中的图像 1,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 8 中的图像 2,3 How to Replace the Fishing Line of a Spinning Reel: 步骤 8 中的图像 3,3
    • Use utility scissors to cut the line free of the spool.
    • Clip the free end into the line holder on the side of the reel.
结论
另外一个人完成了本指南。
Stefan Venne
于01/26/23注册
184 声望
撰写一个指南
团队
UC Davis, Team 2-13, Morris Winter 2023 UC Davis, Team 2-13, Morris Winter 2023 的会员
UCD-MORRIS-W23S2G13
1 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 37
总计 1,055
