跳转到主内容
How to Replace the Fan Blade Assembly on the Utilitech SFC-1 500B 20 " High Velocity Floor Fan
你所需要的
  1. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan, Fan Blade Assembly: 步骤 1 中的图像 1,1
    • Unplug fan prior to repair.
    • Remove the Phillips #2 screws securing the fan cover.
  2. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 2 中的图像 1,1
    • Remove the fan cover.
  3. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 3 中的图像 1,1
    • Remove the screws holding the plastic wire cover with a Phillips #2 screwdriver and flexible extension.
    • If the above attachment is unavailable, use a crescent wrench or pliers to grip the screwdriver for additional torque.
  4. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 4 中的图像 1,1
    • Remove the green wire that is attached to the motor housing.
  5. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 5 中的图像 1,1
    • Remove the nuts securing the motor to the back cover of the fan, using a Phillips #2 screwdriver and an 8mm socket driver.
  6. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 6 中的图像 1,1
    • Remove the power cord from the back cover by sliding the wire off of the two metal rails holding them together.
  7. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 7 中的图像 1,1
    • Remove the motor from the back of the fan cover.
  8. How to Replace the Fan Blade Assembly on the  Utilitech SFC-1 500B 20 " High Velocity Floor Fan: 步骤 8 中的图像 1,1
    • The fan is fully disassembled; replace the damaged parts.
结论
2等其他人完成本指南。
团队
Colorado Springs, Team 1-4, Mcmichael SU 2015 Colorado Springs, Team 1-4, Mcmichael SU 2015 的会员
UCCS-MCMICHAEL-SU15S1G4
2 名成员
创作了1篇指南
6条评论
do you have the wiring schematics for this fan my wire broke from the copper coil thank you
Timothy Thomas - 回复
My Ulitiech fan suddenly stopped working. What can I do to get it to work again. Or is it my new door stop?
Belinda Blodgett - 回复
Where can I find replacement blades for this fan?
Jason - 回复
My cord on my utilitech floor fan was severed by my table saw and I’ve spliced the cord and it still won’t work. Could there be a reset button or something I’m missing?
Steve Case - 回复
You title this on how to remove the fan blades then don't actually show how to remove the fan blades but get the whole motor with the fan blades attached.
Justin Edgell - 回复
The set screw to remove the fan blade is metric. You will need a set of metric Allen wrenches or metric bits to replace it.
Ed Keough - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 39
总计 10,153
