跳转到主内容
How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra
你所需要的
  1. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra, Dashboard Tweeter: 步骤 1 中的图像 1,2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra, Dashboard Tweeter: 步骤 1 中的图像 2,2
    • Take your flat head screwdriver and gently pry off the plastic grille covering your tweeter.
    • There are 4 clips holding the grille down, 1 in each corner. Be careful not to break them.
  2. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 2 中的图像 1,2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 2 中的图像 2,2
    • Take your offset screwdriver and unscrew the screws holding down the tweeter bracket.
    • Some models and years have 2 screws, others have 4. Remove them all.
  3. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 3 中的图像 1,2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 3 中的图像 2,2
    • Gently lift the tweeter bracket with the tweeter inside and locate the connector.
  4. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 4 中的图像 1,1
    • Unbox your new tweeter and place it inside of the bracket that it comes with.
    • Refer to the manual included with the tweeter for this step. Bracket installation varies between models.
  5. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 5 中的图像 1,3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 5 中的图像 2,3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 5 中的图像 3,3
    • Disconnect the old tweeter from the car.
    • Make sure to note that the positive wire has a red line on it. This is important.
  6. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 6 中的图像 1,3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 6 中的图像 2,3 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 6 中的图像 3,3
    • Take your new tweeter and plug it in to the same connections as the old one.
    • Make sure that you connect the positive lead to the lead you noted earlier (red line). Connecting them incorrectly could result in damage to your tweeter or stereo.
  7. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 7 中的图像 1,2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 7 中的图像 2,2
    • If your tweeter only has 2 screws, attach a zip tie through the other holes and over the tweeter to help secure it in place.
    • Cut off the excess tie.
  8. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 8 中的图像 1,1
    • Take any excess cable and fold it neatly so that it will fit down the hole below the tweeter.
  9. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 9 中的图像 1,1
    • Place the new tweeter and bracket assembly back into the dashboard.
    • Make sure the orientation is how you would like it, and that the holes of the bracket line up with the holes in the dashboard.
  10. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 10 中的图像 1,1
    • Place the screws from the original tweeter back in their holes and tighten them with the offset screw driver.
    • Make sure you do not over tighten them! Over tightening can strip the plastic that holds them in place. Snug is good.
  11. How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 11 中的图像 1,2 How to Replace the Dashboard Tweeter in a 2005-2016 Nissan Xterra: 步骤 11 中的图像 2,2
    • Replace the grille that covers the tweeter.
    • Make sure you install it in the correct orientation. It should snap in easily. Installing incorrectly could damage the clips.
结论
You have succesfully replaced your tweeter. Follow the same steps to do the other side and test your stereo to make sure they are installed properly.
4等其他人完成本指南。
Justin McGowan
于09/29/15注册
182 声望
撰写一个指南
团队
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 的会员
CPSU-GREEN-F15S15G5
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 33
过去 30 天: 132
总计 20,671
