跳转到主内容
How to Replace the Cable on the Endgame Gear XM1 Mouse
你所需要的
  1. How to Replace the Cable on the Endgame Gear XM1 Mouse, Mouse Cable: 步骤 1 中的图像 1,3 How to Replace the Cable on the Endgame Gear XM1 Mouse, Mouse Cable: 步骤 1 中的图像 2,3 How to Replace the Cable on the Endgame Gear XM1 Mouse, Mouse Cable: 步骤 1 中的图像 3,3
    • Use the plastic spudger to peel off the four rubber feet on the underside of the mouse.
  2. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 2 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 2 中的图像 2,2
    • Use the Phillips #1 screwdriver to unscrew the four 8.0 mm screws on the underside of the mouse.
  3. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 3 中的图像 1,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 3 中的图像 2,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 3 中的图像 3,3
    • Use your hands to carefully separate the top and bottom shells from each other.
    • The top and bottom shells should very easily separate without any force used to pull them apart.
  4. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 4 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 4 中的图像 2,2
    • Remove the stress relief from the base of the bottom shell.
  5. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 5 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 5 中的图像 2,2
    • Using your fingers, pull the cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained. Avoid forcefully pulling or yanking the cable.
  6. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 6 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 6 中的图像 2,2
    • Insert the replacement cable in the socket by lining up the pins on the socket to the holes on the cable connector, then push it in.
    • Make sure that the two lines on the cable connector are facing the inside of the mouse.
  7. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 7 中的图像 1,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 7 中的图像 2,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 7 中的图像 3,3
    • Route the cable between the scroll wheel and the Omron sensor.
    • Place the stress relief in the designated opening at the base of the bottom shell.
    • Be sure to push the cable down so that it is firmly secured between the mouse wheel and the right mouse switch.
  8. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 8 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 8 中的图像 2,2
    • Line up the top and bottom shell, press them together, and make sure they click.
  9. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 9 中的图像 1,2 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 9 中的图像 2,2
    • Place the 8.0 mm screws in their designated holes, and screw them in using the Phillips #1 screwdriver.
  10. How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 10 中的图像 1,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 10 中的图像 2,3 How to Replace the Cable on the Endgame Gear XM1 Mouse: 步骤 10 中的图像 3,3
    • Install new mouse feet by lining them up with the grooves at each corner of the mouse, and apply pressure to assure that they stay in place.
结论
Heba Azeef
于01/30/23注册
181 声望
撰写一个指南
团队
York University, Team M-5, Allen Winter 2023 York University, Team M-5, Allen Winter 2023 的会员
YORK-ALLEN-W23SMG5
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 65
总计 781
