跳转到主内容
TI-Nspire CX Battery Replacement
你所需要的
  1. TI-Nspire CX Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: 步骤 2 中的图像 1,2 TI-Nspire CX Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: 步骤 3 中的图像 1,3 TI-Nspire CX Battery Replacement: 步骤 3 中的图像 2,3 TI-Nspire CX Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: 步骤 4 中的图像 1,1
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: 步骤 5 中的图像 1,1
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: 步骤 6 中的图像 1,1
    • Replace the back plate and the 2 screws.
结论
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
9等其他人完成本指南。
Jim Kerman
于02/24/15注册
314 声望
撰写一个指南
团队
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 的会员
CPSU-GREEN-W15S24G2
4 名成员
创作了4篇指南
2条评论
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - 回复
Hola Amigo. Pudiste solucionar?
Armando02 -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 120
总计 16,362
