跳转到主内容
简介
The rechargeable battery in the TI-Nspire CX can lose its ability to hold charge over time. Use this guide to replace the battery and return your calculator to optimum condition.
  1. Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • Unscrew the 2 Phillips #0 screws from the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. Remove the back plate using the spudger or by hand. Remove the back plate using the spudger or by hand.
    • Remove the back plate using the spudger or by hand.
  3. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  4. Carefully disconnect and remove the old battery. Unhook the wire from the tab. Carefully pull out the wire.
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the wire.
    • Grip the wire close to the top and pull away.
  5. Plug in the new battery.
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  6. Position the new battery and tuck the wire under the tab.
    • Position the new battery and tuck the wire under the tab.
  7. Replace the back plate and the 2 screws.
    • Replace the back plate and the 2 screws.
结论
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
4等其他人完成本指南。
Jim Kerman
于2015年02月24日注册
191 信誉积分
撰写一个指南
团队
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 的会员
CPSU-GREEN-W15S24G2
4 名成员
创作了4篇指南
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 19
过去的30天: 99
总计 4,187
