跳转到主内容
How to Replace the Battery from an Armitron All-Sport Watch
你所需要的
  1. How to Replace the Battery from an Armitron All-Sport Watch, Battery: 步骤 1 中的图像 1,2 How to Replace the Battery from an Armitron All-Sport Watch, Battery: 步骤 1 中的图像 2,2
    • Remove the back strap.
    • Remove four 1.7 mm Phillips Pan Head screws.
  2. How to Replace the Battery from an Armitron All-Sport Watch: 步骤 2 中的图像 1,2 How to Replace the Battery from an Armitron All-Sport Watch: 步骤 2 中的图像 2,2
    • Pull back on the strap, while keeping a finger pressed to the metal covering.
    • Gently pull away the metal covering away from the watch.
  3. How to Replace the Battery from an Armitron All-Sport Watch: 步骤 3 中的图像 1,3 How to Replace the Battery from an Armitron All-Sport Watch: 步骤 3 中的图像 2,3 How to Replace the Battery from an Armitron All-Sport Watch: 步骤 3 中的图像 3,3
    • Pinch the metal tab.
    • Pull the chip up and out.
  4. How to Replace the Battery from an Armitron All-Sport Watch: 步骤 4 中的图像 1,1
    • Remove two 1.5 mm Phillips Pan Head screws.
  5. How to Replace the Battery from an Armitron All-Sport Watch: 步骤 5 中的图像 1,1
    • Remove the battery.
    • Take note of the orientation the battery is in for proper replacement.
结论
12等其他人完成本指南。
Jose Cabrera
于02/23/15注册
452 声望
撰写一个指南
团队
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 的会员
CPSU-GREEN-W15S12G2
6 名成员
创作了15篇指南
9指南评论
what about the after battery replacement short circuit to reset it? that’s the hard part that totally is unclear!
holograf00 - 回复
With a magnifying glass there is RESET written with a small diamond [THE ARROW] at one part of the back under the battery, On the side there is a slot that you put a piece of flat metal, small tipped screwdriver, into it. This will touch the contacts inside to reset the watch.
Greg Scott -
what about the post battery replacement short circuit reset?! that’s the hard part that’s completely unclear and confusing!
holograf00 - 回复
my comments don’t seem to be working.
holograf00 - 回复
I agree that these instructions are very deficient when describing how to reset the battery. I just spent 1/2 hour resetting an Amitron MD0699. One is supposed to bridge about a 2 mm gap between 2 vertical bands of metal. The space to approach this is very small. A normal paper clip tip is too narrow for this purpose. A large metallic paper clip tip might work, but you will have to prove that the metal is conductive. My micro screwdriver set didn’t work; I didn’t realize the metal was non conductive til I tested it with an electrometer. In the end, the electrometer tip was just the right size. I reassuring little chime rang when the reset occurs. All these little fine points would have made the original post useful.
pkenny - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 35
过去 30 天: 182
总计 72,084
