跳转到主内容
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
你所需要的
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 步骤 1 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 步骤 1 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: 步骤 1 中的图像 3,3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 2 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 2 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 2 中的图像 3,3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 3 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 3 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 3 中的图像 3,3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 4 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 4 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 4 中的图像 3,3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 5 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 5 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 5 中的图像 3,3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 6 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 6 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 6 中的图像 3,3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 7 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 7 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 7 中的图像 3,3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 8 中的图像 1,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 8 中的图像 2,3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: 步骤 8 中的图像 3,3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
结论
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 55
总计 263
