跳转到主内容
How to Replace the Bail Spring in a Spinning Reel
你所需要的
  1. How to Replace the Bail Spring in a Spinning Reel, Spinning Reel Bail Spring Replacement for south bend 840: 步骤 1 中的图像 1,1
    • Remove the screw that holds the base of the bail arm to the reel with a Phillips #1 screwdriver.
  2. How to Replace the Bail Spring in a Spinning Reel: 步骤 2 中的图像 1,2 How to Replace the Bail Spring in a Spinning Reel: 步骤 2 中的图像 2,2
    • Slowly pull the base of the bail arm away from the reel in a twisting motion to separate the two parts.
  3. How to Replace the Bail Spring in a Spinning Reel: 步骤 3 中的图像 1,1
    • Remove the worn out bail spring by pushing down on the spring, then pulling outward away from the reel.
  4. How to Replace the Bail Spring in a Spinning Reel: 步骤 4 中的图像 1,3 How to Replace the Bail Spring in a Spinning Reel: 步骤 4 中的图像 2,3 How to Replace the Bail Spring in a Spinning Reel: 步骤 4 中的图像 3,3
    • Replace the worn out bail spring by separating the pin from the spring. Then place the original pin inside of the new spring.
  5. How to Replace the Bail Spring in a Spinning Reel: 步骤 5 中的图像 1,2 How to Replace the Bail Spring in a Spinning Reel: 步骤 5 中的图像 2,2
    • Place the new bail spring and pin back in the spring slot. Lightly push down on the spring to allow it to sit in its original position.
  6. How to Replace the Bail Spring in a Spinning Reel: 步骤 6 中的图像 1,1
    • Line the bail back up with the reel, ensuring all holes align with each other. Lightly squeeze the bail and reel together to allow the two pieces to snap back together.
  7. How to Replace the Bail Spring in a Spinning Reel: 步骤 7 中的图像 1,1
    • Insert the same screw used in Step 1 back into the hole and firmly screw it in.
结论
By replacing the spring, the entire open bail reel is saved from turning into unnecessary garbage that is harmful to the environment. Happy Fishing!
5等其他人完成本指南。
一条评论
Thanks for the clear pictures and instructions. Your tutorial was helpful along with a YouTube video on bail repair of a very similar spinning reel I have.
Steve McCormick - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 138
过去 30 天: 545
总计 32,692
