跳转到主内容
How to Replace the Arm of Standard Hinge Eyeglasses
你所需要的
  1. How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: 步骤 1 中的图像 1,2 How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: 步骤 1 中的图像 2,2
    • Remove the screw holding the broken arm by turning it counterclockwise.
  2. How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 2 中的图像 1,1
    • Carefully set the screw aside and discard the broken arm.
  3. How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 3 中的图像 1,1
    • Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
  4. How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 4 中的图像 1,2 How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 4 中的图像 2,2
    • Align the joints of the new arm with the joint connected to the frame.
    • The frame joint should be in between the two joints of the arm.
  5. How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 5 中的图像 1,3 How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 5 中的图像 2,3 How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 5 中的图像 3,3
    • Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
    • Make sure all parts are aligned and that the new arm is not angled.
    • You may want to put the glasses on to make sure the arm is positioned properly.
  6. How to Replace the Arm of Standard Hinge Eyeglasses: 步骤 6 中的图像 1,1
    • Once aligned, fully tighten the screw.
    • You may need to make adjustments to the tightness of the arm. Tighten (turn clockwise) or loosen (turn counterclockwise) the screw until you have a comfortable fit.
终点
2等其他人完成本指南。
Mariam
于01/16/23注册
193 声望
撰写一个指南
团队
York University, Team N-8, Morris Winter 2023 York University, Team N-8, Morris Winter 2023 的会员
YORK-MORRIS-W23SNG8
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 68
过去 30 天: 305
总计 2,687
