跳转到主内容
How to Replace and Install Ceiling Light Fixtures
你所需要的
  1. How to Replace and Install Ceiling Light Fixtures, Ceiling Light Fixture: 步骤 1 中的图像 1,1
    • Turn the main power off.
    • Ensure that the circuit breaker is off to avoid electrocution. Optional use of a circuit tester to verify the power is off.
  2. How to Replace and Install Ceiling Light Fixtures: 步骤 2 中的图像 1,2 How to Replace and Install Ceiling Light Fixtures: 步骤 2 中的图像 2,2
    • Remove the cover of the old light fixture.
    • Unscrew all lightbulbs.
  3. How to Replace and Install Ceiling Light Fixtures: 步骤 3 中的图像 1,3 How to Replace and Install Ceiling Light Fixtures: 步骤 3 中的图像 2,3 How to Replace and Install Ceiling Light Fixtures: 步骤 3 中的图像 3,3
    • Remove the screws holding the old light fixture's housing with a screwdriver
    • Carefully pull the old light fixture and its wiring down.
    • Without the screws, the housing will no longer be attached to the ceiling. Hold the housing until it hangs gently to avoid injury.
  4. How to Replace and Install Ceiling Light Fixtures: 步骤 4 中的图像 1,3 How to Replace and Install Ceiling Light Fixtures: 步骤 4 中的图像 2,3 How to Replace and Install Ceiling Light Fixtures: 步骤 4 中的图像 3,3
    • Remove the old wire connectors and untwist the wires.
    • The old light fixture will completely detach. Prevent it from falling by holding onto the housing.
  5. How to Replace and Install Ceiling Light Fixtures: 步骤 5 中的图像 1,3 How to Replace and Install Ceiling Light Fixtures: 步骤 5 中的图像 2,3 How to Replace and Install Ceiling Light Fixtures: 步骤 5 中的图像 3,3
    • Match the new ceiling light wiring to your home’s existing wires.
    • Link each pair with wire connectors by placing the exposed ends inside, and twisting down until tight.
    • If your home does not have a corresponding grounding wire to connect to:
    • You must connect the fixture ground wire to the ground screw of the ceiling crossbar.
    • Or you must connect the fixture ground wire to the house ground wire (the bare copper wire without any insulation)
  6. How to Replace and Install Ceiling Light Fixtures: 步骤 6 中的图像 1,3 How to Replace and Install Ceiling Light Fixtures: 步骤 6 中的图像 2,3 How to Replace and Install Ceiling Light Fixtures: 步骤 6 中的图像 3,3
    • Find the proper alignment for the holes of the new housing with the ceiling's mounting bar.
    • Carefully place all wiring into the electrical box or empty space within the ceiling.
    • Secure the housing to the ceiling with two screws, tightening them firmly with a screwdriver.
  7. How to Replace and Install Ceiling Light Fixtures: 步骤 7 中的图像 1,1
    • Attach the cover and/or lightbulbs of the new light fixture.
  8. How to Replace and Install Ceiling Light Fixtures: 步骤 8 中的图像 1,2 How to Replace and Install Ceiling Light Fixtures: 步骤 8 中的图像 2,2
    • Turn the main power back on and watch as your handiwork lights up the room!
结论
Alexandria S
于02/08/24注册
157 声望
撰写一个指南
团队
York University, Team 1-2, Morris Winter 2024 York University, Team 1-2, Morris Winter 2024 的会员
YORK-MORRIS-W24S1G2
5 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 63
总计 1,383
